LEMII
Sep 09, 2013Explorer
Jayco 23B Mattress Issue - Unevenness
2007 Jayco 23B. Two-piece mattress set up with the narrower piece having a built-in offset. When the bed is assembled, there seems to be some unevenness between two pieces that causes me to roll toward the joint between them. Looked at it carefully and checked it with a straight edge; looks like I need a 1-inch thick "spacer" to fix it; I'm thinking of a piece of foam rubber of some sort.
Anyone else run into this issue? How did you fix it? Where might I find a suitable spacer locally?
Thanks.
Thanks.
