โFeb-28-2010 07:12 PM
โSep-30-2019 04:43 AM
โSep-30-2019 04:42 AM
โJul-06-2018 07:53 PM
โJun-09-2018 07:29 PM
โJun-09-2018 07:23 PM
โMay-28-2018 05:58 AM
โFeb-02-2018 08:09 AM
โFeb-02-2018 06:52 AM
โJul-18-2017 08:26 AM
mtmcj wrote:
Well I spent the weekend rebuilding the door. No more wood in there now, I used 1" thick dow corning super tuff rigid foam board, put two aluminum channels in the foam they where 2 1/2" wide by 46" long with a 1/2" intrusion into the foam. A sheet of white aluminum for the inside and reused the filon siding for the outside. Glued it all together with 3m 90 industrial adhesive. Less than a $100 in material and 1 1/2 days of work. oh and sealed up the outside channel with dap 230 clear sealant. Door is lighter than factory and if anything more rigid. Looks good and works great Now if any water gets in there it will not rot. Only concern is the struts are a little strong for the door now but I will keep my hand on it when opening. Now to seal the crack in the toilet.
โJul-18-2017 07:29 AM
โJul-13-2017 03:49 PM
โJul-13-2017 01:27 PM
โMay-11-2017 05:01 AM
โMay-10-2017 08:57 PM
Andy F wrote:
I am going with 14 inch load range D tires after crunching numbers and taking into consideration all of our cross country trips with our original 14 inch load range C tires and rims without any issues at all. I would really have liked to move up to 15 inch rims and tires but too many unknowns right now with a large mess and external investigation with my employer. Still loving our Bullet as we begin season number 6. It looks and feels brand new!
