- Farmboy666Explorer
Lynnmor wrote:
If it has no gravity fill, then you open a valve to direct the city water to the tank. It is also possible that a winterizing hose is used to draw in fresh water and direct it to the tank.
Either way you have a valve somewhere close to the tank inlet you need to turn to open for filling and using pump for pressure or close to use city water pressure. - LynnmorExplorer IIIf it has no gravity fill, then you open a valve to direct the city water to the tank. It is also possible that a winterizing hose is used to draw in fresh water and direct it to the tank.
- SoundGuyExplorer
leenave wrote:
I bought a used 2009 Komfort Trailblazer T24S and can't figure out how to fill the fresh water tank. I can connect to city water but can't find another fill point or a valve. Any ideas?
What you're looking for is a gravity fill, like this ...
However, some manufacturers have fooled around with using the city water inlet and a valving system that when set correctly will direct that water to the fresh water tank. I have no idea whether yours is one of them but if you have no gravity fill then it will be a valved system. That said, did the seller not go over this with you? :@
About Travel Trailer Group
44,054 PostsLatest Activity: Aug 13, 2015
