Weekendwarrior2's avatar
Aug 07, 2020
Lance 830 with Ram 3500 Mega Cab
I know this has been discussed before and I'm probably going to get the same answers from the same 2 camps, but I thought I'd try anyways.
I have a Lance 830 and love the camper, but it is a bit too much for my '04 F250 so I'm looking for a new truck to haul it and the Ram 3500 Mega Cab looks pretty appealing. Here's the dilemma;
Ram Short beds are about 76" long and the rear axle appears to be 34.5" from the front of the cab (mega cab and crew cab). The Lance 830 lists COG as 36" from front and 42" from rear (I believe where the wings almost contact the tail lights). Since this bed is shorter, we can probably just focus on the 36" measurement. This puts me 1.5"-2" behind the rear axle. Not ideal right?
But then I found this from Ram in 2016.
https://www.ramtrucks.com/assets/bbg/pdf/2016/docs/ram/hdramcg.pdf
I don't think any of these measurements have changed since 2016. According to this I'm within the recommended "zone" for COG.
The Truck I'm looking at is a 2020 Big Horn 3500 6.7 HO cummins Mega Cab 4x4 SRW. GVWR should be 12,300. Payload should be around 4K lbs.
I always have gear on the floor of the camper up front so I know this shifts the true COG forward a bit, but if I'm dropping the money on a new Diesel I might as well get it right. Do I need to go the Ford route?
Thanks,
Chris
