otrfun
Aug 07, 2020Explorer II
The manufacturer's COG is only accurate the day the camper left the factory. The COG is constantly changing. Adding/removing batteries, propane, gear, mods, water, etc. will move your COG forwards and backwards. How much weight you lose/gain on the front axle tells you more or less where your *current* COG is.
That being said, the *factory* COG on our camper (almost 4k loaded) is about 4-6" behind the rear axle. Truck is a '16 Ram 3500 CC SB (same 6'4" bed as a SRW MegaCab). Zero handling issues.
