sichejo's avatar
sichejo
Lance 915 LP Regulator
I have a 2001 Lance 915 Lite, it has a single 20lb. horizontal LP tank. It has a 2 stage horizontally mounted regulator. I need to replace to regulator because it is leaking around the crimped housing. I called Lance, they said the regulator is discontinued. It is in a tight space, does anyone know of a replacement?
  • I found a replacement regulator. It is a Fairview GR-9959. It is for a single tank, and the regulator mounts horizontally with the vent facing down like the original. No cover is needed to protect it from moisture damage since the vent is facing downward when mounted.
  • Lance said the company that produced the regulator went out of business.
    Actually, that is exactly how I found out the regulator was bad. The guy that re-certified the tank told me. He said, that was a special regulator, and I would have to order it from the dealer.
    Back to square one...
  • Have a visit with a propane dealer. They will likely solve your problem by replacing the existing or finding the appropriate substitute replacement. I would be curious as to why Lance did not have the substitute replacement solution for you.
