โApr-30-2014 04:50 PM
โMay-05-2014 08:44 AM
โMay-03-2014 09:50 PM
โMay-02-2014 10:57 AM
โMay-02-2014 09:52 AM
travelnutz wrote:
mkirsch,
So true that RV furnaces do not work like Rollin described and note he reference to an automotive heater which uses engine heated water etc liquids. Not chance of fire as the liquid is around 200 degrees which is a mere fraction of burning fuel flames. We ARE talking about RV furnaces and propane burning flames as that's what this thread is about. It would be unlawful and never pass muster and there'd fire after fire if the blower fan wasn't first in RV's.
However, home furnaces can and most modern ones do work different as they have TWO fans in the furnace system. The combustion chamber blower small fan and the big blower fan to distribute the heated air. The small combustion chamber fan comes on first after the "call for heat" signal comes from the thermostat and forces any raw gas fumes out of the combustion chamber. After a preset timed delay, the gas valve opens and the igniter is activated. POOF! The burning flame heats the chamber and the plenum to a preset temp or period of preset time and then the big blower starts up to deliver the heated air. When the thermostat setting is reached, the gas valve closes and the flame goes out. The big blower fan continues until the plenum temp lowers to the preset temp (some use time) and then it shuts off.
Wood type stoves may or does have a heat activated sensor that turns on the blower after the unit's heat is sensed to be high enough.
Different animals and they require different controls and operation's sequences.
โMay-02-2014 08:56 AM
โMay-02-2014 08:11 AM
Rollin wrote:
Hey fikkellin, I'm sorry I didn't catch the typo can for fan. However, moving air will be cool unless it is warmed by a hot firebox or hot heater coils in a car. The fan should not come on until the firebox reaches a set temp. If the fan cycles on and off a lot when it is extremely cold while the burner keeps going then its going to take a little longer to get to t-stat set temp.
โMay-02-2014 06:59 AM
โMay-01-2014 09:34 PM
โMay-01-2014 06:01 PM
โMay-01-2014 12:09 PM
โMay-01-2014 11:17 AM
mkirsch wrote:
The blower is running, according to the OP.
The problem is the furnace burner is only running for 2 minutes, then shutting off.
This could be one of two problems:
1. A vent is blowing hot air right on the thermostat.
2. The burner is sensing that it is getting too hot, and shutting down to prevent a heat exchanger meltdown.
If your heat exchanger is caked with dust it can prevent the efficient transfer of heat to the air being blown through by the fan.
โMay-01-2014 10:38 AM
โMay-01-2014 09:26 AM
โMay-01-2014 09:08 AM
Rollin wrote:
Well, I just had to coment on this subject. Travelnutz pretty much nailed it. Heating systems for the most part are closed loop. If the abient air recirculating inside is so cold that it cools the firebox down, then the blower control will close down so that the burner can raise the firebox temp back up. When the firebox reaches a certain temp then the blower switch closes and the blower engages, as the abient temp increases so does the blower on time. When the set abient temp is reached then the burner will close and then the blower.
