Laundry options?
Obewan
Thinking of adding a washer/dryer combo to our new TT (pre plumbed) but am confused re vent vs vented. Will be on the road in this unit for 4 months this summer. I see on some reviews that the vented options "steal" conditioned air from coach thus heating the coach up and are slow to dry. Spoke with an installer who says not to get a ventless cause they heat up the coach and are slow to dry. Have a very heavily coated dog that doesn't tolerate much heat and need to keep him cool. I'm guessing that both are slow to dry... But on the topic of heating up the trailer???? I'm not real keen on cutting a hole into the side of a brand new trailer! Anyone have experience with these, vented or ventless and the merits/faults of each?
2015 DRV Mobile Suites 44 Lafayette Walden
2014 Ram Laramie 3500 dually
9 REPLIES 9
IRingTwyce
I'll throw in my opinion, since I use one regularly. Due to work, I live in my 5er 2/3 of the year and bought my first trailer specifically because it came with a W/D. I have a vented Splendide, probably the most common one out there. First, they dry slowly because they're 120v more than any "vent issue." Second, you can't overload them or you'll break them. They can dry a larger quantity than they can wash, weight being the factor.
Practically speaking, you can figure on combo washing/drying two full changes at a time, and that's stretching it. I usually throw in 2 of each in one load: jeans, shirts, socks(pair), and underwear. Start when I leave in the morning, and when I'm off of work they're (usually) dry. Bed linens suck though. You can manage one sheet and one pillowcase per load, so sheets take a minimum of two loads. If you're "home" dealing with laundry, figure on one complete load taking at least 3 hours, if not longer.
Proper venting is essential with these things, as they have no built in lint filter. What doesn't get drained with the wash will eventually build up in the exhaust. Extended regular use will have the unit shutting off with error codes during the dry cycle (starts happening to me about every 1 to 1-1/2 years). A few phone calls with the very helpful Splendide repair line, and I was told to shove a water supply hose down the top exhaust port and back-flush into the unit, draining the water every so often. 3-6 times of doing this and you're good for another year or so until the lint builds up again.
So....there's my long winded endorsement of the vented combo unit. Just read the instructions carefully, as they spell out the typical shortcomings of the unit.
waynec1957
I've seen these small washer and dryers in TTs and 5ers we've looked at. Having never used them, my impression was as small as the capacity is it seems to me in order to keep up with the laundry you would have to do it daily or at least every other day.
2013 Chevy Sliverado 2500 HD LS Crew Cab
Duramax/Allison, HD Tow Package, GCWR 24,500
2017 KZ Sportsmen S330 IK
ScottG
I wonder if an intake could be created for the dryer to draw air from outside the RV. Maybe a pipe going straight down under the rig?
Cuffs054
I've had both. I will never go back to ventless. Vented is the way to go.
donn0128
rockhillmanor wrote:
I'll just say take a good long hard look at how 'small' these RV washer and dryers are. One pair of jeans is about all you are going to get into them and wait forever for them to dry.
In my travels about 99% of CG's have a laundry facility right there on the grounds a couple feet from your RV, with real adult size washers and dryers! Pack'em to the hilt with all your dirty clother and go back to your RV and have a cold one. IMHO Just saying! JMHO
This from someone who probably has never had or used one. Personally I don't like putting my clothes in a machine that who knows who has stuffed with who knows what. Paranoid? Maybe, but why should I use something that might have been used to wash greasy clothes? While they do smaller loads they work just fine. There are a few tricks you will learn. We do wash and dry all of our clothes in it with no problems. And we have an older one with the smaller drum.
BB_TX
I think both arguments about the heating are lacking much merit. We have a vented combo, live in the Texas heat, and have not noticed any heating problems. Works great for us.
The vented models work just like a home unit and blow heated air thru the dryer and out the vent. So, yes, they do displace some of the internal air.
The unvented models take longer to dry clothes and use a lot more water. They put cold water into the machine to condense the water vapor from the heated wash load and drain it out the drain pipe. They do not put moisture back into the RV as some have said in the past.
rockhillmanor
Mandalay_Parr
Vented one for sure. No question.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
donn0128
Yes, both are some what slow. But the nice thing, start it and go out exploring. When you get home clothes are done. The secret is to not overload the washer. Get the vented model for sure. Ventless ones are useless, they basically boil the clothes dry.
