eb145
Aug 30, 2012Explorer II
LCI electric tongue jack - fix that worked for me - some oil
I have had lots of frustration with the LCI Electric Tongue Jack that came with my 2 year old trailer. It looks like this:
It was so unreliable. I found if I banged on the outer tube with a steel pipe it would usually work. Recently it has been getting worse and totally failing me.
I laid down to look at the bottom part when it was last stuck - I saw the inner tube that moved up and down was slightly corroded/chalky and it was binding against the outer tube it moved through because the angle the trailer was at. Hmmm.... so I sprayed the inner tube with WD-40 and life is good - at least the jack is now 100% reliable for me (for now).
For good measure I extended the jack and put a coating of motor oil on the outside of the whole inner tube.
I guess I'll hold off on my Barker upgrade for now.
Ed
Ed
