JoeChiOhki
Mar 23, 2021Explorer II
LED Replacement bulbs high moisture environment survival
As I am at the stage where I am installing Ms. Merry's light fixtures , I thought it prudent to inquire from the rest of the community if anyone had any experience on if a particular LED replacement bulb brand (the round canister kind that plug into the standard bases) that held up better in a wet bath environment where the ambient moisture levels in the air are regularly high held up better than another.
The market is chock-a-block full of brands and replacement bulbs now from all different manufacturers, including some of the more well known RV brands like Camco, so I'm not sure whose bulbs produce the highest lumen levels and are low electro magnetic noise (some of the cheaper bulbs as I recall created alot of electromagnetic interference from threads in the past) and can survive being in a wet bath.
Any suggestions on higher quality brands to look for is greatly appreciated.
The bulbs will be getting installed in new Arcon single and dual bulb fixtures (They produce replicas of the original Bargman vintage interior lights) with opaque lenses for the under cabinet, doorway and bathroom (the main kitchen area and dinette overhead lights are ThinLite 40W flourescent tube fixtures that use the nice larger replacement tubes that you can still find readily stocked in hardware stores.
