markandkimExplorer IIAug 28, 2014Lift trailer under frame or axleWhile performing maintenance on the axle bearings or brakes. I keep hearing that one must lift and support the trailer by frame lift, not axle lift. Why is the case, if true? When CW came out to ch...Show More
pasusanExplorerAug 28, 2014It depends on what type of axles and frame your trailer has. Best bet is to check in your owner's manual.
Related ContentLippert framesHeartland/Lippert Trailer Frame CreaseSub frame additionFrame issue5th Wheel Frames
