markandkim
Aug 29, 2014Explorer II
buzzard616 wrote:
Slight twist to the topic but I'm curious about 'ramping' one wheel to raise the other off the ground.
Doesn't that result in the ramped wheel/tire/hub supporting almost twice the design load?
Stu
Very good point. When you jack under the u-bolts, at least both axles are still loaded.
I have decided that jacking under the axle u-bolts is the best option. Just enough to get the tire off the ground.
44,025 PostsLatest Activity: Feb 18, 2025
