yillb's avatar
yillb
Lifted truck towing :(
Hey Guys,
I'm trying to determine if my math is correct, hoping some of you that understand this better than me can assist.
I have a Dodge ram 1500 ( 2016 ), with a 6" pro-comp lift. It's just spacers, but I do have proper control arms, sway bars, pretty much everything to make it not a budget lift, the only thing still stock is the springs.
With that said, my GVWR is 6900 on my truck, with me, my wife, the lift ( heavy ), and two children, the truck comes in at 6400 pounds, that leaves me with 500 for payload ? meaning i'd have to get a TT in the 5k range, is that correct ?
I've added airbags, it gives me 500lbs on each side, effectively, 1k additional payload capacity. I'm trying to tow a TT between 6500, and 7500LBS, the truck itself is rated for 10500, However, due to GVRW i'm concerned i might be over doing it. I had everything professionally installed by a place that sells RV's ( just a coincadence ), so I understand the sales aspect, versus the actual utility aspect of what i'm trying to do. I found a very nice 28foot TT i'd really like to bring home, I'd like to ( using my basic math here ), be sure that i'm in a safe range here. My tires are rated just fine, and my sag will be minimal with the bags in. Any insight would greatly be appreciated.
