Timtation
Oct 05, 2014Explorer
Check wheel alignment, get a temp sensor gun if you don't have one and go. I check hub and tire temps every day at the first or second rest stop. Check tire pressures weekly on the TT, the TV has a monitor. If you don't do the temp thing check the tire pressures daily and put a hand to the hub if you haven't braked hard going to the rest area/stop.
My guess is that with today's equipment there are more operator oversight problems than mechanical problems, old tires, low tires, lost pins, unlatched awnings, loose stuff in the RV etc.
jmho
jmho
