- ktosvExplorer
MM49 wrote:
The new CVT JATCO transmissions are great. It is very obvious that many have not driven them. Normal RV.Net information.
MM49
Or it's vehicles like the Nissan Juke and Versa that in my opinion have a very crude control system on their CVT. I had a Nissan Juke the first two weeks of December for a business trip and all I had to due was close my eyes and stick my head out of the window and I would have thought I was on my 1997 snowmobile. I have previously had a Versa with similar thoughts.
After driving a vehicle like this I would be very hesitant of dumping $30k on a vehicle with a CVT thinking this is what I am going to get. - JN_BExplorer
Lessmore wrote:
I believe most manufacturers using a CVT are using CVT Jatco transmissions...including Subaru, Jeep AND Nissan.
You are correct on the Jatco/subaru, but subaru had one made to their specifications.
I've driven the nissan murano, and it is nowhere near the same as the subaru. Even if it is all just programming due to subaru i-drive, the subaru one is ALOT better. - LessmoreExplorer II
JN_B wrote:
MM49 wrote:
Subaru has doubled-down on CVT tech. Look at their entire vehicle line-up.
MM49
No kidding, My wife's forester XT is a great vehicle, and lots of fun. I was one of the doubters prior to driving it. Being able to simulate gears and manually shift through them is awesome. We went from a 2013 Outback with the 5 speed auto, to the forester, night and day difference. The outback transmission was very dated, and the programming was horrid.
I believe most manufacturers using a CVT are using CVT Jatco transmissions...including Subaru, Jeep AND Nissan. - JN_BExplorer
MM49
No kidding, My wife's forester XT is a great vehicle, and lots of fun. I was one of the doubters prior to driving it. Being able to simulate gears and manually shift through them is awesome. We went from a 2013 Outback with the 5 speed auto, to the forester, night and day difference. The outback transmission was very dated, and the programming was horrid. - DaveF-250SDExplorerWith this many speeds, how far away will folks be from a 7-10k transmission overhaul when they go south? Yikes.
- MM49Explorer
MM49 - 3oaksExplorerDepending on the application and intended use of the truck, not necessarily better, but certainly different.
- Golden_HVACExplorer4.5:1 first gear, and 0.65:1 double (or is it triple) overdrive!
That is a wide spread between first and top gear ratios. Great job.
So to start out at 5 MPH with a huge load on the transmission, the engine can build up speed quickly, with 4.5:1 axle ratio, and say a 4.1:1 rear axle ratio. This will allow the engine to turn 18 times for each turn of the tires! 1,800 engine RPM = 100 tire revs per minute. or 6.6 minutes to go 1 mile.
At 0.65:1 ratio, the engine running 2,000 RPM will have a output shaft speed (say the transmission transmits all the RPM, and not lose one) the output shaft will be turning around 2,700 RPM. The same 4.10:1 rear axle reduction will bring this down to around 658 tire revs per minute.
If the tire outside diameter is about 30", then it should be turning around 660 revolutions per mile. 658 tire revs per mile - about 60 MPH? With a diesel, it would be better to have the 3.73:1 rear axle, or 2,700/3.73= 720 revs per minute or about 65.5 MPH at 2,000 RPM.
If you have the gas engine then the upper speed limit would be well over 120 MPH. Diesel is limited to around 110 MPH by the engine RPM governor. If you really wanted to go for speed, then a 3.23:1 rear axle ratio will lower the engine RPM's at all road speeds.
Looks like we will all have a better truck in a couple of years!
Fred. - BedlamModeratorTheir little Justy with CVT was pretty weak, but they have learned a lot since 1987. Back then the CVT would wear too fast before needing parts.
- jus2shyExplorerSubaru has doubled-down on CVT tech. Look at their entire vehicle line-up.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
