Matt1221's avatar
Matt1221
Mach 15 a/c not cooling well
I have a 2020 travel trailer with a coleman mach 15 in a 33ft travel trailer, with 2 bedrooms. In the back bedroom I have a portable a/c with the door shut, that room is no concern to me other than it would be a no go without it in the texas sun.
The 15k btu coleman mach 15 only task is to cool the living quarters living kitchen etc. we keep the other bedroom door closed.
When the sun is out & with a heat index of 94-95+ the best the a/c can do is about 81 degrees. At night it will freeze you out but during the heat of the day warmish air out of any of the ports including the dump vents.
It doesnt' act 'froze' up either... We keep the filter clean. I was thinking either the wall t-stat is faulty or possible the freeze switch is faulty shutting off the compressor.. What are your thoughts?
