davidx2000's avatar
davidx2000
Magic Chef oven burner supply line
I have Magic Chef CLZ1610ADB range, and the supply line to the oven burner was snapped off at the flare by storing a cutting board in that area. A mistake that we won't make again. I don't have a picture of the actual broken fitting at this time. TT is in storage still - I'll try to get a photo this weekend when I pull it out of storage.
I found this part on PPL Motorhomes - and wondering if this is match? While they do not list parts for the CLZ model, they have a CLY1610ADB model. It's described as "TUBING, 3/16" 41 3/4" INCLUDES FITTINGS Price: $60.09" No picture online of it.
Has anyone replaced this tubing before? Do I need to remove the range from the counter to replace or repair this line?
Can the flare be redone at a hardware store or with a tool? I found online 3/16" brake line with a flaring tool. Can I make my own with brake line?
I appreciate any help you can provide! Thank you!
  • Call PPL they have been most helpful to me.
    I have worked with a woman named Julie Stiles who seems well informed and personable.
  • If the tube is long enough you can easily reflair it. Cut the line put the nut on and reflair the line and hook it back up. Call any local plumber explain to them what happened and they should be able to take care of it for you in 5 minutes.
  • Thanks for the suggestions. I'm pulling the trailer out of storage this weekend, so I can get a better look at it and remove the line and/or the range.
