NTORACN wrote:
Thanks for the info Hone Eagle.
Does having air brakes in a non commercial application require a class A license? Not sure if the little woman would want to learn shifting a road ranger tranny. I was also looking at using the MDT as a vehicle to drive around when at our destinations when not bringing my Landcruiser. Not sure if I would want to drive an HDT on city streets too much. Not that an MDT is as easy as a compact car to park, but seems to be a happy medium between the HDT and a LDT. I will revisit the HDT option again before rendering a decision.
Merry Christmas
hone eagle wrote:
NTORACN wrote:
HDT's are good affordable, powerful tow rigs. However, feeding a 10 liter engine yields about 5 or 6 MPG. I think an MDT will yield around 10 or 11 MPG and is overbuilt for the 20 to 25,000 Lbs my loaded trailer will probably weigh. Thanks for the advice.
Dennis M M wrote:
Personally I think you will be way better off looking at a HDT instead of an MDT.
Much greater capability and a lower cost of entry.
Do some reading on the Heavy Duty Truck Forum
Not true ,most do close to 8-9 mpg
Mine runs 9.5 on a U.S. gallon
Spend some time as suggested on the HDT forum
no 'class A or cdl' required ,they are either motorhomes or private plated mine is a motorhome and less to insure then my previous SD.
automated transmission, DW drives it bobtail- no clutch peddle.
cost per mile is the same as my old 7.3 because of the size of the tanks I can fuel in the cheapest state every 2000 miles or about once a season.
Come to one of the rallies for HDT's bring the wife if she thinks you are loon and meet the other ladies.
While you shop and drive MTD's ask the following -?
-how quiet is this MTD?,(my floor is 3" thick)
-are the doors double sealed that is 2 offset rubber gaskets on the perimeter?
-air bag suspension on ALL axles?
-air suspended cab?
-air suspended seats?
Those are some pro's ,there are also some cons ,head over to the escapees and read and read
many have come from MTD's and will recommend skipping them unless it meets a very specific need.
