bobsrvnet's avatar
bobsrvnet
Moisture Issue - Ideas to locate source?
Good day all, I'm a little frustrated with my Frontier TT as I recently noticed a moisture buildup in the very front left corner underbelly. The protective canvas and insulation is obviously very wet and heavy for approx. 24 inches from the front corner directly under the side access hatch. There are no signs of water damage or water stains anywhere inside the cubby including the flooring of the cubby.
I do have some seam cracks which need to be filled as you will see in the following web link to some pictures I took. I also punctured a small hole in the canvas as you will see to confirm if there was a pool of sitting water but I see now its the insulation which is wet, heavy, and not drying. The wood beam running along the bottom edge is apparently soft as well. The side sheeting seems fine and undamaged in any way.
You will see the seams along the cubby are definitely in need of some new sealant and water could be getting in at the top edge or also from the front nose seams which you can also see in the pics however as mentioned there is no water damage anywhere else I can find.
Any ideas would be greatly appreciated.
http://imgur.com/a/3HHag#0
  • It only takes a pin hole to allow water and moisture in. Looking at the photos, you definitely need to re-work your seems. Check around your clearance lights, and corners. Pull the molding cover off around the edges and look for rusty screws. Rust screws indicate water/moisture contact
  • I would open up that bottom covering to let it dry out completely and replace the wet insulation. Then caulk those seams that are cracking. That is probably where the moisture is entering.
    You may find some rotten wood in there also when you open up the bottom. That must be repaired or it will spread and you will have an even bigger problem on you hands.
    Barney
