Jonnygsx
Jan 22, 2015Explorer
Need advice for a ruined roof
Awhile back I bought my first travel trailer. A 98 prowler 24lz. I knew nothing about RV's at the time and made some mistakes. The biggest was that the roof was completely shot when I got it. Almost all of the white chalking has worn off leaving only black rubber over 95% of the roof. The front and rear seams were pulling away from the edges. I tried to repair both seams as best I could using staples and eternabond. The rear seam is looking pretty good but the front seam is not so much. The rubber has actually lifted up from the wood under neath so there are some bubbles and just loose rubber around the seam. I bought Liquid roof to try and coat it but i'm worried about the loose rubber. I feel like having a flexible bubbly spot is not goin to be good. Whats my best option, should I just try and staple the bubbles down before I coat it? Should I cut it back and try and spray adhesive in there before I coat it?
The other problem is that i've found out this liquid roof coating is going to be very difficult for me to install myself. I don't have a place to do the install, i'd have to do it out in the boondocks while camping. Also my roof isn't supposed to be walked on so spreading the liquid roof around would be very difficult having to move a ladder every few feet. I was planning to have a local RV shop where its stored do the install but they are going to charge more than $800 just for the install. So the price of the liquid roof, plus primer, plus install is going to be $1000-$1500. For that cost could I get some other RV shop to do it right and actually replace my whole roof?
The one saving factor I have is that I keep the RV stored in Bishop California in the eastern sierra. The annual rainfall is less than 6" there. So hopefully even if the roof isn't perfect with low rainfall not to much damage will be done.
Live and learn I guess. I knew I was going to make mistakes when buying my first trailer. Just not sure how to proceed from here to try and extend the roof life as best I can. Hoping someone can offer advice.
