FireGuard's avatar
FireGuard
Jan 21, 2020
New Ford 7.3 Gas
I’m planning to get back to truck camping by fall and spend a lot of time seeing the country. Life is short and I’m not getting any younger.
I’ve had many trucks and campers and have been a loyal Dodge/Ram Cummins fan.
However, with the cost and complexity of the new diesels I’m considering a gas engine.
I like simple, basic and reliable and the new Ford 7.3 seems to be that engine.
With old school cam in block design, it’s about as basic as they come.
The power numbers seem pretty impressive (430 hp/475 to) and it makes over 400 ft/lb of torque below 2000 rpm. The 10 speed transmission will make it even better.
It adds about $1700 to the standard gas package so about $8k less than the diesel.
It’s also a lighter and smaller engine due to the design which will help payload.
They are starting to show up at the dealers but it’s a new design so really no long term reviews yet.
I would likely get the DRW and would prefer 4:30 gears but may have to order as 3:73 seem to be common.
I’m thinking the only negative is the fuel mileage but the new diesels aren’t getting what they used to and gas is much cheaper as well as the $8k savings of buying a diesel.
Also, no $10-15k out of pocket cost to replace the fuel system when the pump fails and contaminates the entire system.
I was really disappointed to see Ram switch to the CP4 fuel pump for 2019.
This may be a great TC hauler.
