- GrandpaKipExplorer II
Lynnmor wrote:
Here is a discussion from a few years ago: Old News
Kinda puts to rest the whole thing, doesn’t it? - GulfcoastExplorerI did install the type that unplugs from the side of my trailer, it works great.
- GulfcoastExplorerI didn't know that
- myredracerExplorer IIIt's due to the "mutual heating" effect. For example, it's why code limits the number of romex cables going through a hole in a wall stud and why cords on electric space heaters shouldn't be coiled up. If you're drawing literally only a few amps, you'll be okay but if say in the summer with AC(s) and other stuff running, not a good idea.
One thing I really don't like about a cord stored in a box inside a TT is that it takes up a lot of valuable space. I converted a previous TT to a detachable cord and I was able to make the box's space accessible through an existing exterior storage door and gained an enlarged storage compartment. Bonus!GrandpaKip wrote:
Atlee wrote:
billroz wrote:
A power cord coiled inside your rig is not safe
Indeed. My owner's manual says to pull the entire cord out of the "mouse hole" receptacle. I've always been told it's best not to keep a power cord tightly coiled when plugged in.
Curious as to why. Only thing that comes to mind is possibly creating a magnetic field around the coil.
Adding an extension cord could lead to a voltage drop. - SoundGuyExplorer
Which is why, if you're not using a detachable main service cable, you're better to cut the trailer's hard wired main service cable down in length so it just reaches outside where it's convenient to connect to an extension cable. In any case where I've done this that's always been 5' or less so voltage drop even at a full 30 amp draw would be an insignificant 0.30 volts over that short length of cable. No question, stuffing just a few feet of stiff 10 gauge cable back through the mousehole is FAR easier than trying to stuff in 25 - no tangles, no heat issue. :B - wnjjExplorer II
Heat, but that’s only if you’re drawing a bunch of power. - GrandpaKipExplorer II
Adding an extension cord could lead to a voltage drop. - AtleeExplorer II
Indeed. My owner's manual says to pull the entire cord out of the "mouse hole" receptacle. I've always been told it's best not to keep a power cord tightly coiled when plugged in. - billrozExplorerA power cord coiled inside your rig is not safe
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 21, 2025
