Today was explore the water system on my 77 Dodge conversion. The plan was to add a small amount of bleach and fill my 15 Gallon tank, let it sit for 4 hours and flush. Filling the tank went smoothly
![](http://i.imgur.com/1ysOJYQl.jpg)
I pulled the bed/couch apart to view the tank and check for leaks
![](http://i.imgur.com/BRSVcG0l.jpg)
I turned on my Shurflo pump and it ran but no water got to the sink....
so I thought maybe the pump needed primed and pulled the faucet to try to pour down it to the pump
![](http://i.imgur.com/z8XCoeLl.jpg)
I heard water coming out somewhere and looked into the cabinet below the sink and found the priming water pouring out sadly....
![](http://i.imgur.com/ilnyuVEl.jpg)
![](http://i.imgur.com/eeRhmYGl.jpg)
Yeah that is not good....so I found a hose clamp and used my solar lantern for illumination and got my hands wedged in there to work
![](http://i.imgur.com/S5c3eg6l.jpg)
Voila, repaired.....
![](http://i.imgur.com/kSyy9Upl.jpg)
After fixing this I tried priming but water wouldn't go down to the pump so I added more water at the hose to try to put a mild amount of pressure to move the water forcibly to the pump and that worked! Good flow! Flushed the bleach out and put about 11 gallons or so in and all good.
