โNov-07-2015 03:27 PM
โNov-18-2015 03:17 PM
IdaD wrote:GeoBoy wrote:
I agree with NC Hauler, that I won't overload a vehicle, based on the mfg. ratings. I was told no problem putting a 2016 AF 990 on my 2005 Silverado 3500 SRW rated at 9,900 lbs. GVW. Just put a set of air bags on it. I decided to sell my loved, 44k miles, Silverado and purchased a 2015 GMC Sierra 3500HD dually with a 13,025 lbs. GVW and I am glad I did that AF 990 scaled out at 4880 lbs. with water! That is just shy of GM's recommended slide-in truck camper rating of 4913 lbs.. I did add Timbrens just to firm up the ride and reduce sway.
You're comparing a less capable truck to a more capable truck.
We were comparing two identical trucks with a different sticker on the B pillar.
โNov-18-2015 02:29 PM
โNov-18-2015 02:17 PM
โNov-18-2015 12:26 PM
NC Hauler wrote:IdaD wrote:NC Hauler wrote:mkirsch wrote:
NC Hauler,
Rather than beat around the bush, I'll ask this question direct:
Would you limit yourself to 10,000lbs with a 10,000lb GVWR F350 SRW pickup truck, even though the only difference from a standard 11,500lb GVWR F350 SRW is a number on a sticker?
I stated what I stated... I don't care what model the truck is.. I go by trucks posted GVWR and it's posted GCWR. It's the reason I own the truck that I do. Again, this is very, very unpopular on this forum..Thus the reason I'm referred to as the weight police and even ridiculed by some who want to only use, and justify RAWR's and tire weight ratings.. Believe me, I DO understand ALL the numbers...not only RAWR's, but also the manufacturer of the rear axle and THEIR weight rating, which is normally even higher, it's just the way I prefer to do it...I've been called names and even lost friends on this forum for what I post at times on this topic.. but I KNOW I will have NO questions on if I'm going to be overweight, or if I'm going to have to "mod" something on my truck to make it work.
I've told others, when they are trying at times to justify what they're towing with, about using their RAWR and tire weight ratings to let them know how to wring out every ounce of CCC they can have, though I personally don't use this formula...it's just the popular way it's presented on this and a few other forums...I tend to actually believe it's safer to go with manufacturers suggested weight limits and figure the TV will last longer...Again, understand, it's not popular, you get called names, but I stand by my convictions....Everyone will make up their own mine as I have, and feel good about their decision, as I have.
Jim
Hey everybody gets to have an opinion. But the part in bold...I don't get it. They are literally the same truck other than a sticker on the B pillar. How on earth is one safer or going to last longer than the other when they are identical?
All hail the mighty payload sticker I guess. :E
I addressed a question as to what I'd do...if both trucks are identical, and they fell within the guidelines of manufacturers recommending towing weights for what I was towing, , it wouldn't make any difference then which one I got, would it?
i messed up and further stated my philosophy, right or wrong...and yes...as stupid as I may seem to you and others...I go by posted GVWR, GCWR...
โNov-18-2015 12:22 PM
NC Hauler,
Jim
โNov-18-2015 12:15 PM
Bedlam wrote:
Although I respect NC Hauler's opinion, I do not have to agree with it. Once presented with all the information, we can each choose the option that best satisfies our comfort level.
โNov-18-2015 12:06 PM
โNov-18-2015 11:55 AM
โNov-18-2015 11:49 AM
NC Hauler,
Jim
โNov-18-2015 11:36 AM
NC Hauler,
Jim
โNov-18-2015 10:01 AM
mkirsch wrote:
NC Hauler,
โNov-18-2015 09:26 AM
โNov-18-2015 05:35 AM
Bedlam wrote:
Some people have to live with 10k lb restrictions and this gives them a truck that is only papered that way yet has more actual capacity.NC Hauler wrote:
...If one were to purchase the right TV for the job at hand,or match up what they're going to tow with what they're towing with, they wouldn't have to do "minor wheel and suspension upgrades to comfortably and safely tow a 5th wheel with 3,000# of pin weight ". Just common sense.
