Newbie: it appears tank hoses don't come with new trailer
chovy
Is this normal? If so I assume I need to buy some...for dumping etc.
Got any recommendations?
20 REPLIES 20
valhalla360
Nomad III
Nomad III
Depends how you will use it:
- Seasonal site where you never (or rarely move): Get PVC pipe and do a semi-permanent install. Do keep the valves closed until at least half full. If you leave the valves open, the solids don't get pulled out and pile up in the tank until they block it.
- If you are staying longer term but moving around, getting the hose supports are nice as they stop sewage from sitting in the hose and smelling (yes, the smell will go right thru the hose if it sits.
- If you are pretty regularly on the move (rarely staying more than a week): You just hook up to dump, so no real need for supports.
Consider hoses as disposable items. They will fail periodically (even the expensive ones).
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Tvov
chovy wrote:
Thanks. Do you recommend getting the hose supports or is waste of space?
Are you going to be a "seasonal" at a campground? Stay at one campground for an extended period? If so, the hose supports are really nice to have.
If you are doing weekend camping at different campsites, I would put that near the bottom of my list of things to get. When we camp for a weekend, I just dump on the morning we leave, I don't stay hooked up all weekend.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
rexlion
Here's another vote for the Rhino hose. I also like the Flush King attachment, which goes between the valve and the hose and allows you to attach a water hose for backflushing the black tank.
Remember to always add some water to the black tank prior to using the toilet for #2, so you don't get a 'poo pyramid' built up under the toilet.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
enblethen
Some places require hoses to be off the ground. In that case supports are necessary. Supports
e dump our tanks, then put hose away. We normally only stay at full hook up locations a day to three.
Rhino flex kit is a good choice. Rhino Flex kit
Get a good quality drinking water hose. Drinking water
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
chovy
rlw999
Seems to depend on the dealer but maybe in today's seller's market they don't feel like they need to give any freebies.
But you probably don't want it anyway, the free hose I got with my RV is the cheapest possible hose that probably cost the dealer $5. I stuck it in the back of a storage compartment "just in case", but have never used it.
You'll get as many different opinions here as there are brands, my preferred hose is the Camco Rhinoflex, with a clear fitting on the end so I can see when the tank is running clear.
