cewillis's avatar
cewillis
no more horizontal propane tank for me
I wanted a standard grill propane tank when I bought my camper new, but it wasn't available. So when the original needed to be re-certified, I decided to change it.
Larger pictures on web site: link
Here is the almost end result --
First, disconnect the propane output.
Which is behind the stove.
Stove out - propane disconnected.
I think this could use a couple of large washers (and caulk).
I think the tank container will come out.
Everything out -- nothing destroyed. Now what?
Cut a hole big enough to tip in a vertical sheet metal box.
Prototype for new sheet metal. Not going back now.
Fits -- went back in the same way the original came out (almost).
Tank fits too (can't use that one of course).
That much room for a replacement short drawer, and a decent size compartment - with a new cabinet door.
New box. May have over-paid for this, but he was close, did an excellent job, and was the only one that gave me a price.
New box installed -- except for support for the bottom.
Removable support -- in case anyone ever wants to take it out.
Use up the rest of the propane in the old tank.
Pressure test at 20 times the nominal pressure. (don't try to pressure test with the regulator in the system).
Ready to go - after I reinstall the door, and a little simple carpentry inside to shorten the old drawer and use the new space.
No change to the camper frame or skin.
