sonuvabug
Oct 18, 2017Explorer
No Water Out Of My Fresh Water Low Point Drain Valve
I just winterized my truck camper. When I went to drain my fresh water tank, nothing came out. I ended up using the on board water pump to drain it. I'm thinking the drain line is somehow blocked? ... or the valve is not functioning as it should?
The drain valve plumbing comes out of the fresh water tank in the basement at the back of my truck camper and it is only about 1 foot long. You can visually inspect the entire drain line and there is no obvious problem. I was thinking about "snaking" the drain somehow but have never done this. What suggestions do you have?
