Canyon-Cruiser
Aug 07, 2013Explorer
OK guys, check your nuts!
Seriously though, camping the other weekend I took a shower and when I finished there was water coming out from under the shower base. I put towels down to dry it up and more came out. Left towels down (just in case) for the trip home. When we got home and checked they were soaked. I had drained the water from the low point drain before we left to come home so I was wondering "where is all this coming from?". When I opened the access panel on the shower base, the cutout in the floor for the drain trap was wet with a little water still in it. Well, I dried that up and poured some water down the drain. Sure enough, almost as much come out from around the drain flange as was going down it. I removed the trap to dry the water up and started to tighten the flange nut. Yep! It was finger tight only. I used a pair of large channel locks and slowly, due to lack of space, tightened the nut until I squeezed the plumbers putty out the sides. Yes, they had put plumbers putty around the drain but never tightened the drain flange nut to seal it. After that I also checked the drain and water supply line nuts on the sinks also. They were not leaking but were far from tight.
So, check your nuts! (flange nuts that is) :)
