teardrop55's avatar
teardrop55
Old water heater drain
Hello all, this is my first post and I have a question about a water heater. I have 78 Fleetwood Prowler. It has been stripped down to the frame and Im building a teardrop trailer on it. My question is that the old water heater that was in it has a garden hose connection in the access panel. Its very difficult to get to since it is up behind the gas tube for the burner. There was no plug in it and it leaked water out of it when i filled it to test the water heater operation. What is this connection for? Theres no way a hose could have been hooked up to it. I bought a plastic garden hose connection plug for it so that i could fill it and test it but it still leaks. Is it supposed to be a one way valve that is now leaking? Was it supposed to be used to flush the water heater or is it just a drain for it? Hopefully one of you guys have seen a water heater this old and can tell me. From what Ive seen all the new ones have a screw in metal pipe plug or anode rod for the drain which would incredibly more simple for me. Thanks in advance.
