- kohldadExplorer IIIAt least in the 2002 model year and up, the wall is framed for a 3" x 6-3/4" opening. Send me a pm with your email and I will send you more details for the 2002 and up models.
- cavieExplorerSure it can. I just did it to my 2002 wildcat 5th wheel. be sure you buy a 12 volt range hood. You have to be 1/2 handyman. You have to cut a 3 1/2" x 10 " hole in the side of your camper. You then find a 12 volt nearby power source and your all set. If you should run into a wall stud leave it alone and just blow the air around it if it metal. If it's wood, cover it with metal. This is just in case it ever cough fire.
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 01, 2025
