towpro
Jun 19, 2016Explorer
please recommend USB outlet that works Boondocking
I charge my phone at night. one of the new Androids that uses the Turbo charging system 2X.
My Wolf Creek has a USB charger built into it, but it don't even work when the shore power is plugged in.
There is also a 12V outlet present.
But when I am boon docking, I don't have 120V and the 200W solar only boost the voltage during the day time but I need to charge at night.
I have Two 90Ah 12v AGM batteries,so surely I can afford to charge a phone.
can any body recommend USB charger that meets the following:
1) will run off 12V. standard 12V car type plug, OR replace my 12V USB adapter that is in panel mount.
2) Will run off 12V, meaning batteries are not being charged by solar or AC power, so it will not be 13.X volts, it will be 12.4v-12.7V that you see with a battery that has a little load on it.
all the car chargers seem to be designed to be used when the car is running, which means they see 13.X volts
