myredracer
May 28, 2016Explorer II
prichardson wrote:
When placing the jack, position it under the spring pad or the trailer frame. DO NOT place under the axle inboard or outboard of the spring pad or frame mount if a torsion axle.
Good point, forgot to mention that.
If you have overslung axles (axle tubes underneath the springs) you will be putting the jack and block of wood under the U-bolts which of course are rounded. You have to be careful to the jack and block of wood centered directly under the U-bolts so it won't slip to one side.
