Putty?
Redterpos3
I'm changing one of the outside lights on my trailer for an LED unit (the original had broken). What is the putty stuff that is between the light and the trailer? I'm sure it's helpful in keeping water out, but not sure what I need to get? Also, do i use dicor along the edge or something else?
The Travelin' Terrapins!
2016 Ford F-350 SRW;CC;4x4;172WB;6.7PSD;34,000m
2011 Nash 27T 12,995m
2013 Yr1 30nts 3150m
2014 Yr2 52nts 3365m
2015 yr3 25nts 2260m
2016 yr4 46nts 2500m
2017 yr5 24nts 1720m
2018 yr6 4nts 30m
15 REPLIES 15
enblethen
Here is Lowes page
gray butyl weather-stripping
I would get the tacky tape from RV store
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
RVcircus
GrandpaKip wrote:
Lowes has Gray Butyl Rubber in a roll. It's made by MD and is in the weatherstrip section. Been using it for years as a bedding compound for hardware on the camper and the boat.
Thanks! I'm sure I've looked right past it all this time.
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
GrandpaKip
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
CampingN_C_
I looked for the 'putty/butyl tape' at Lowes when I did a rebuild on my last camper. They didn't have it at the time. All I ever found was normal weather stripping that you would use around the house.I had to go the the RV store, maybe something has changed.
2018 Ram 3500 DRW CCLB Aisin 4.10 4x4
2018 Jayco Talon 413T
B&W Companion
RVcircus
4X4Dodger wrote:
I have bought Butyl tape at Lowes and Home depot in several areas of the country. And it's much cheaper there. also usually a good hardware store will have it. It is quite common and should be pretty cheap.
What section of the store do you find it in? I've never seen it art Home Depot or Lowes, but then again I haven't looked. I usually just order online, but it would be nice to pick it up locally.
Tax_Man
I am with 4x4Dodger. Just because it on an RV does not mean that it has to be from an RV store. Other than the self leveling Dicor sealant (Lowe's didn't know what I was talking about), I try not to buy from my local RV shop.
Traveling around with the wife and fur kid.
Keep on Truckin (It's a 70s thing)
2022 HR Vacationer 35K (Ford Chassis)
2007 Jeep Liberty Limited 4x4 (Toad)
4X4Dodger
CampingN.C. wrote:
You'll need to go to an RV place, not Lowes, Home Depot etc.
No, No, NO You do not need to go to an overpriced RV store.
rockhillmanor
Tax_Man wrote:
I used the tacky tape then a tiny bead of white window/door sealant around the outer edge
X2
I found that putty tape turns black within days and you can't clean it off and it looks terrible. I used it to replace the water drain and am really sorry I did.
CampingN_C_
B&W Companion
therink
If you are looking for a putty tape, it is called butyl putty. Very inexpensive. I have always bought mine online. Not sure if this is what you are referring to or not.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Redterpos3
Thanks all!! I appreciate the help! Now will head to the hardware store and pickup the needed item. And will check my "weep" holes!
2018 yr6 4nts 30m
RoyB
I was checking things around one of my two outside scare lights and noticed it had a wep hole in the lens. I looked at the other one and the wep hole was on top and the inside area was half full of water up to where the wiring came inside the trailer. I have been noticing some water inside one of my high mounted cabinets...
Good catch on my part. Rotated the lens to get the wep hole on the bottom and that solved my water problem..
Be sure to check your outside lens for a wep hole and make sure it goes back on the bottom after you take it out... The smaller outside porch lights may not have one...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
beemerphile1
The putty tape is available in rolls. The butyl tape which is also available in rolls is far superior.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Tax_Man
