jmatthews's avatar
jmatthews
Question about main breaker
Hello all,
Last weekend I went on my second trip with my new 2013 shasta revere.
We ran into an issue. I was plugged into shore power 30amp service at the CG. It was pretty hot so the air was running. I went to use the microwave to pop some popcorn and we had a black out. At first I thought the CG was at capacity and there was some sort of surge. It turns out my main 30 amp breaker tripped. This was only running the AC. The microwave should not trip the main I am thinking it should have tripped the breaker for the microwave not the main. So it is going in for service at the dealer I bought it from this Sat to test all systems and see if there is a problem with my TT. I had the CG check the power at the site to make sure it was not dropping too low or spiking. It seemed pretty constant at 116.7 using a meter.
I have read of a lot of folks having this issue but it just does not make sense that a brand new trailer you cannot not run the AC and the microwave at the same time. My old 97mallard never missed a beat when doing so. I guess I may be expecting too much but I thought it would handle at least two appliances at one time.
Oh no smell or excessive heat coming from breaker either. Just a trip and shut off.
Thanks,
