Sep-28-2013 12:06 PM
Sep-29-2013 05:19 PM
Sep-29-2013 05:10 PM
Sep-29-2013 03:24 PM
Morningstar page 3 wrote:
Q2. Can I exceed the nominal wattage ratings of MPPT controllers? Will it void the warranty?
You can size Morningstar’s MPPT controllers well above the Maximum Nominal Solar PV Input rating without damaging the controller and without the charging current exceeding the maximum output current rating. The controller can limit output current and will run at 100% of rated current output and not higher. The controller was designed with this power-shaving capability and when oversized it does not void the warranty
Page 5 wrote:
In this case almost twice as much energy is gained (green area) than lost (red area) with 12.5% more energy available to charge the batteries than the 200W module.
Sep-29-2013 02:32 PM
brulaz wrote:
The Rogue manual suggests a little formula for determining the "maximum usable PV array power when taking into consideration system losses"
PV(watts) = (A x Vb) / 0.90
A is the amperage rating of the MPPT controller, Vb is battery voltage, which he takes to be 14.4V for the 3048 with 12V batteries, and 0.90 is the assumed efficiency.
So the new Rogue 20A MPPT controller should handle a 320W array.
By the way, the downloadable manual is a very useful source of info.
Sep-29-2013 10:43 AM
JiminDenver wrote:
Since we had already discussed what a system can actually run, I had a pretty good idea that you were talking cost. I'm sure the Rogue 20a wont be Eco-worthy cheap but there is a need for a affordable basic controller.
Sep-29-2013 10:19 AM
Sep-29-2013 09:38 AM
smkettner wrote:69 Avion wrote:
Any idea what it will run?
Generally a controller does not run anything. Controller charges the battery.
20a 12v will run anything up to 240w. But you can run anything you want from an inverter connected to the charged battery.
Or do you mean what solar panel?
Sep-29-2013 09:22 AM
Sep-29-2013 08:03 AM
69 Avion wrote:Did you miss my last post?
Sep-29-2013 07:26 AM
westend wrote:lorelec wrote:There you go, Avion. A perfect fit for your situation.
Rogue will be coming out with a 20A MPPT around the end of the month. 100v max on the PV input, 12v or 24v battery. There's a pic of it and little more information about it on the Rogue Facebook page.
Rogue Power Technologies on Facebook
Sep-29-2013 04:34 AM
Sep-28-2013 10:46 PM
Sep-28-2013 09:25 PM
Sep-28-2013 09:11 PM
69 Avion wrote:JiminDenver wrote:
Do you go up in altitude? My 230w panel sees a increase of over 50% at altitude, you may be loosing more than you think.
I've had good results using the Eco-worthy 20a MPPT controller with a single panel. I was hoping one of the really low cost ones would at least functions but no luck so I'll be getting a second Eco-worthy for the inverter bank.
Jim, how has your Eco-Worth MPPT controller been working? It is the only one that I can find in the 20 amp range. It appears that it will work well with my 250 watt, 24 volt Sharp panel. The price is certainly better than the others as long as it actually is reliable and it works. Let me know what you think.
I may buy two panels since there is no extra shipping for the second panel and then just buy a second Eco-Worthy MPPT controller. I like the fact that it is reasonably sized. When you go to the Morningstar TriStar MPPT 45 amp controller, it is huge for RV usage.
Sep-28-2013 08:56 PM
ktmrfs wrote:69 Avion wrote:
I have ordered a 250 watt Sharp 24 volt Solar panel. Now for my question. I would like to use a Morningstar Sun Saver 15 MPPT controller. The problem is that the sales person said that the 15 amp MPPT Sun Saver controller isn't large enough for my panel. Does anyone have experience with this? I don't want to have to go to a 45 amp controller unless I absolutely have to.
He's correct. 250/13=20A that's what the controller will try too dump as a maxx into the batteries. I have the sunsaver 15 controller,wonderful controller but not for a 250W panel.
