starzen's avatar
starzen
Question regarding used travel trailers
i was looking at a used 2013 coachmen freedom express with a slideout
it looks like it was in good shape but one thing i noticed was that both side walls on the slideout (the ones that are hidden when closed) are not bonded at all.
is this normal on this trailer or is there something wrong?
pretty much all other trailers i looked at the walls have the same feel as the vacuum bonded main walls.
thanks for any help
  • i checked with coachmen and they said that indeed the walls on the slide out on this trailer are not laminated or glued but just held in place on the outside.
  • The ends of my slideout are fiberglass with a Masonite type backing and have no additional backing. They appear to be glued to the actual wooden framework of the slide room
  • when you have a huge hole in the side of a camper that twists and flexes as it goes down the road, what could possibly go wrong?
    Since 2008, some mfg's are hanging filon in smaller locations. The sheets are usually held in place by a tongue and groove section on top then molding holds the sides and bottom as it basically just hangs in place . They do not glue them . No delamination to occur.
    However, they still can leak. A good way to tell , remove one of the screws at the bottom of the molding . That will be a low point in the design and water will collect there and drip out when you remove the screw.
    Some people have been known to actually remove a screw at the bottom to allow a potential water leak , an avenue of escape.
  • it almost seems to me like it is supposed to be that way because the whole side is like it. not like there are bubbles or anything and the material underneath is solid
    but i want to make sure before i go further.
  • I've seen some both ways. Someone with the same trailer will have to give a definitive answer.
