bkenobi's avatar
bkenobi
Questions abou t new (to me) Northern Lite
I just picked up my first TC last week. I'm going to be taking my first trip next weekend and need to get a couple things figured out. The first is critical, the second is maintenance that will come into play down the road.
1) The NL TC is a 2007 10'2" RRQ (rear dinette, queen bed). It was kept in great condition by the original owner fortunately. But, the TC did not come with a sewer hose. There is a hole/door in the side of the camper that is 17" deep that I've been told is for storing the dump hose. I picked a relatively cheap one up from Walmart but found it does not fit either. It's both too large diameter (the hole is 3-3/4" diameter but the hose coupling is closer to 5"). Secondly, the hole is not deep enough to hold anything longer than 5' and can't hold the 90deg bend. I probably need to contact NL about this, but what the heck am I supposed to use in order to dump sewage without adding an aftermarket hose holder tube?
2) The Happijacks are functional and in good visual condition. However, there are some chips/cracks in the paint that some rust is coming through. What should I use to paint this? Since it's regularly going to get wet and has to take some abuse, I was leaning towards marine grade paint, but a recommendation for what others do would be nice. I'll probably look into contacting Happijack to see if they have a suggestion, too.
