Oct-30-2014 12:34 PM
Oct-31-2014 01:10 PM
Oct-31-2014 12:44 PM
Old-Biscuit wrote:
Programming issue........have you had it into a dealer, explained it and had a 'reflash' done?
Oct-31-2014 11:55 AM
mileshuff wrote:Old-Biscuit wrote:
And no....the EB being ON will not cause you tranny shifting issues.
On 2007.5 Dodge 6.7L's EB most certainly does cause tranny downshift issues. Over the years I posted and searched numerous forums. I'm not the only one with the issue. Dodge's firmware does change shift patterns with EB on similar to when T/H is on. It is only a problem when driving in city traffic and occurs when accelerating slowly then letting off on pedal just as it was about to shift from 3-4. It downshift extremely hard. As far as I know Dodge has never corrected this issue on the 2007.5's. I use EB only on the highway where it works fine.
Oct-31-2014 11:09 AM
Oct-31-2014 10:01 AM
blkdodge wrote:
The dealer didn't charge for it because it fell under the 100k warranty. I do a lot of stop and go driving every day. Freeways here suck. 1.5 hours to drive 37 miles. So I guess there really isn't anything I can do to prevent this, except park it. :h
Oct-31-2014 08:46 AM
Rollnhome wrote:I think that's "like you done stold it."
Drive it like you stold it.
Oct-31-2014 08:42 AM
Oct-31-2014 07:30 AM
Oct-31-2014 06:33 AM
ChooChooMan74 wrote:
I didn't know dodge made trucks any longer...
In all seriousness, do you idle your truck before shutting it? Oil coking in the turbo is bad. My diesel tech is adamant about it. I wait to my pre turbo EGTs is below 300.
Oct-30-2014 10:42 PM
Oct-30-2014 09:08 PM
FishOnOne wrote:ScottG wrote:FishOnOne wrote:ScottG wrote:
Two very different things are being discussed here...
"Coking" is caused by shutting down a turbo (gas or diesel) that is extremely hot and has not been allowed to cool. When this happens the oil inside the turbo's oil gallery is heated to the point it turns to a solid. This blocks off further flow resulting in a damaged bearing and poor turbo action.
It has nothing to do with short trips, not driving it hard enough, too hard or anything but hot shut down. It also has nothing to do with carbon build up inside the turbo. That is a totally different subject.
It is certainly not a "Dodge" or Cummins thing. In fact it is extremely rare in those.
It certainly is a cummings thing and the dealer is certainly using the wrong term "coking" because you would not flush a turbo for a coking problem. Cummins added a cleaning port to the turbo because of this issue.
I'm sure it's the soot clogging issue that happens on a lot of first gen 6.7 cummins and there a flush kit used to clean out the turbo.
The problem here is this cleaning is a short term fix and the turbo will soot up again.
A "cummings" thing? Ridiculous brand bashing at its best.
The big three had growing problems with VGT in the beginning. ALL of them had issues and the Ford was just as susceptible as any other brand.
If they have the updates, are driven right and have the EB left on then no, they won't just "soot up again".
Ridiculous brand loyality at it's best! Cummins owns Holset so spin it however you want.
Ford's early VGT turbo problems was mostly due to rust.
And just so you know this cleaning kit is connected to the turbo! :W
MOPAR Diesel Turbo Cleaner Video
Oct-30-2014 08:41 PM
Oct-30-2014 08:35 PM
Oct-30-2014 07:50 PM
Oct-30-2014 07:28 PM
