Rbertalotto
Jul 20, 2013Explorer
"Shtopintheslidenarounda"...Stoping the camper from sliding
2006 Dodge SB, Palomino Bronco 1200...Plastic Bedliner...
My truck has a plastic bed liner that I do not want to remove as I use my truck more as a truck than as a camper hauler.
But my Palomino Bronco real slides around in the bed.
So....
My bedliner is deeply ribbed:
I need to put a couple 2X4s under the camper so it clears the sides of the truck. I have a roll up toneau cover that has a set of aluminum rails that run along the bed top edges.
So to keep the 2X4s in place I nailed a couple pieces of half round molding that fits perfectly into the bedliner ribs:
On the side that the camper sits on I stapled a few pieces of bicyle inner tube:
Camper doesn't move at all now! I did some "Parkinglot Loops" to see if I could get it to slide around....Solid as a rock!
So....
