GordonThree's avatar
GordonThree
Ram 1500 - 12v power to trailer
I've upgraded my tow from a 290 hp station wagon to a 395 hp truck and it's really made a difference pulling my little Sportsman.
One thing the Ram lacks, and it's minor, is the ability to charge the trailer batteries.
My wagon had an after market trailering package installed, and once I upgraded the ground wire in the car side of the 7 way, it provided almost 30 amps to the trailer. 30 amps isn't huge, a drop in the bucket to my 800 AH battery bank, but still better than nothing.
The Ram, a 2013 1500 "Outdoorsman" (factory 7 way setup and factory brake controller), on the other hand provides a measly 10 amps to the trailer. The gas solenoid on my fridge takes 3 amps, the inverter's electronics on standby takes another amp or so, leaving 6 amps to charge the batteries.
The trailer safety lights all work, and shine brightly. The 10 amps is measured across a precision shunt by the battery management controller which is part of my inverter setup.
Have other Ram drivers noticed a low charge current through the factory 7 way on their truck?
Only mention I find of power supply for the trailer battery is fuse F30, 30 amp, named "Trailer Tow Receptacle". The fuse is intact. I next opportunity I have to fiddle, I will pull it and see if BAT+ goes out on the 7 way.
