โMar-25-2015 09:52 AM
โMar-29-2015 07:50 PM
Bionic Man wrote:
Except that every comparison that I have seen states that, comparably equiped, the EB and EcoDiesel are priced very similar. You can state that it is $4000 more expensive as many times as you want. It doesn't make it true.
โMar-29-2015 05:57 PM
Huh?!? First you say you would never WOT your truck up a long grade and don't believe in abusing machinery. Now you are defending a truck that had to go WOT and was stressed out barely holding 50 mph(10 mph under the speed limit) when it was not even carrying the max weight the Ram rated it for versus a truck that was considerably less stressed pulling the same weight while easily able to do the speed limit. You are contradicting yourself which makes me wonder what is more important to you, your own beliefs or your need to defend a Ram product? It seems like your own beliefs are taking a sideline here.
No, the Ecoboost would be less stressed than that Ecodiesel. Not only was the Ecoboost running at a lower RPM, but the higher compression ratio of the Ecodiesel puts more stress on the block than the Ecoboost. However, that is a moot point since the both these engines have a CGI(Compacted-graphite iron) block like the the bigger diesels do to handle the stress. Diesel engines are inherently "overbuilt" to handle the stresses of compression ignition which is one of the reasons why they last longer, and the 2.7L EB is built the same way with less stress on the block to make it's power.
Lastly, the reason why gasers never achieve EPA numbers has more to do with the fuel uesed and the test itself. If you read how they do the test you will find that they never exceed 60 mph so if one thinks they will get the EPA numbers at 70 mph then they are being overly optimistic. Another factor is the fuel. The EPA test uses non-ethanol gasoline which is rare in the real world. Most gasoline at the pumps is E10 which reduces your fuel efficiency by about 5% which is a 1-2 mpg loss for most trucks. For the diesel test, the EPA uses the same stuff you get at the pumps as summer #2 diesel so you don't get that loss right of the bat like gasoline. However, you will get a loss in the cold months(usually October to March) when stations switch over to winter #1 diesel that has about a 5,00-8,000 Btu reduction in energy which reduces your power and fuel economy.
โMar-29-2015 01:25 PM
โMar-29-2015 12:38 PM
jus2shy wrote:ShinerBock wrote:
Do the math of the added $4,000 cost of the Ecodiesel over the 2.7L Ecoboost. The added cost of maintenance where both are recomended to change the oil at 10,000 miles but the Ecoboost oil change will cost about $40-50 to where just the oil filter alone for the Ecodiesel cost about that much. Edmunds.com reported that the oil change for their long term test Ecodiesel costs them $154 here..
Not going to dispute the oil change cost, as that's the reality of many european diesels. Best price I could find the oil that the 3.0 calls for is 7 bucks a quart in the open market and the filter is especially heinous in price @ 50 bucks. However, you can't compare the $4k up-charge for the Ecodiesel against any other vehicle except the vehicles in its line (Hemi and Pentastar). I've personally optioned up an F-150 XLT against a RAM Bighorn (2.7 versus 3.0) and found that they nearly matched in price and several other automotive rags made the same observation (Motortrend).
However, maintenance costs for the Ecodiesel at this point will be higher. Still, I wonder how the hell they get away with a $25 fuel filter when the HD diesel guys have to spend roughly $100 for fuel filters... Well, I wonder what the ISV in the Nissan will do as many believe, for RAM, that's the engine that got away.
Then there is the added cost of diesel in the mix. Going by the EPA highway numbers and the most up to date average cost of gasoline versus diesel in the US of unleaded being $2.457 with diesel being $.40 higher, the 28 mpg of the Ecodiesel is equivalent to a gasoline engine getting 24 mpg which is well below the 2.7L Ecoboost EPA numbers so the Ecodiesel would cast more in fuel. If you go by the real world combined numbers that most review sites are getting for both engines(Ecodiesel 23 mpg and 2.7L Ecoboost 20 mpg) then you would still pay more in fuel for the Ecodiesel than the Ecoboost per year. So there's no added fuel cost benefit there either unless you were towing more than 15% of your annual mileage which most don't. There is also the factor that Ram only offers the Ecodiesel with a 27 gallon tank while the Ecoboost can be optioned with a 37 gallon tank giving you a longer or equal range for the most part even when towing.
Again, this depends on where you live and where you do the majority of driving. Diesel in the PNW has flipped flopped with Unleaded for the past few weeks and unleaded is only about a dime cheaper than Diesel as I type this. Where as in the northeast, Diesel is way more expensive than gas. Then for realistic fuel economy, I like to look at the fuel economy curve for the manufacturers. Ford 2.7's fuel economy really can't be determined because there isn't enough samples yet. But the sample base is building and in 6 months, we should get a clear picture of where the average is. As it stands, the distribution is from 16 to 21mpg with no curve to speak of. As for the Ecodiesel, it seems to have a great number of users posting between 21 and 26 mpg average (I'm ignoring the outliers on the high and low sides). That's a 5 mpg difference from lowest to lowest and highest to highest when comparing curve to curve (although the 2.7 will need more samples before we can firm-up an analysis between the two). But as it is, that's 25% fuel economy difference from Ecoboost to Ecodiesel.
So basically, this is what you get with the Ecodiesel over the 2.7L Ecoboost. You have to pay about $4,000 more for it up front. You have to pay over 3 times as much for maintenance. You have to pay more in fuel for most of the time unless you tow more than 15% of your annual mileage. All this for something that has less pulling power, less payload, and struggles to even keep within 10 mph of the speed limit going up hills. So where is the benefit in it?
I think people are being blinded by only looking at the MPG number and the fact that it is diesel, but neglect to look at the big picture and do the math. I can see paying more for the Ecodiesel if it had better towing performance and more capability along with its fuel mileage which is why I went with the Cummins over the 6.4L Hemi in my 2500. However, I can't see paying more all the way around and getting less performance and less capability. It just doesn't make sense.
Again, that's some broad generalization. Some people, the math works out, others it doesn't. Some people merely want the ability to carry bulky, but light items along with their family and many never hook a hitch up to a half ton truck. The Ecodiesel works well in that regard and those that occasionally tow something small. I'm not in that boat, and many on here are not in that boat.
โMar-29-2015 12:29 PM
โMar-29-2015 11:49 AM
โMar-29-2015 11:30 AM
SGardiner wrote:
If your looking for a daily driver with good fuel economy that can also pull your 7,000 lb TT it looks like a good option to me.
The ike gauntlet is the exception and likely the most extreme conditions you would ever see.
โMar-29-2015 11:23 AM
โMar-29-2015 11:03 AM
wilber1 wrote:
I would never run my truck or any of my other vehicles at WOT up a long grade or just about any other time for that matter, so what it will do at WOT doesn't mean much to me. I don't believe in abusing the machinery just to get up a hill a minute or two faster.
wilber1 wrote:
Why do you have to go up the mountain at 50 mph? Everything is a compromise and everyone choses the compromise that works best for them.
wilber1 wrote:
They do? I think they are both interesting trucks and if I was looking for an economical half ton I would check them both out. I do take some exception to the idea that the EB is working less hard because it is working below it's rated max power. Everything else being equal, I would expect a 2.7 L engine to be more stressed than a 3.0L engine when producing equal HP. I would also wait until more real world fuel economy numbers come in as the smaller diesels have a reputation of meeting or exceeding EPA estimates while gassers never seem to. Time will tell but I think both trucks will sell well.
โMar-29-2015 07:09 AM
โMar-29-2015 06:55 AM
โMar-29-2015 04:25 AM
Look at the video again. The Ram Ecodiesel was screaming (for a diesel) at 3,500-4,000 rpm at wide open throttle only being able to do 50 mph for most of the way up with no power to spare if needed. It struggled almost all the way up the mountain and took longer to get up the mountain.
Ram 1500 3.0L Ecodiesel tows 7,200 lbs up the Ike Gauntlet
The 2.7L Ecoboost was between 2,500-4,000 rpm not at wide open throttle most of the way while easily able to do the speed limit with power to spare if needed. It had the quicker time up the mountain with little struggle.
Ford F150 2.7L Ecoboost tows 7,200 lbs up the Ike Gauntlet
Ironically, the Ram gives that 1500 Ecodiesel a higher tow rating than what Ford gives that 2.7L Ecoboost. This is what I am arguing about because I think it is a bunch of bull because like you, I don't think a vehicle should have to struggle that hard with no power to spare when towing less than it's max. I think that Ram needs to lower that tow rating on that Ecodiesel to something it can do without struggling so hard.
Why? because the sae tow standard that Ram fans constantly throw out there -uses this hill and that speed limit?
If it failed 'the standard'..........
โMar-29-2015 03:01 AM
โMar-28-2015 10:43 PM
โMar-28-2015 06:26 PM
