Grit dog wrote:
You have 2 filters and change them both if at 15kmi on orig filters.
Warning, dealer will charge you about $200 for the filters and probably an hour at least to change them.
Even on a discount the filters cost about $100 for the pair.
Sorry to hear about the other stufff......
This is not quite accurate. As the owner of a Dodge Ram 2500 CummimsTD I have had several discussions with dealers about this fuel filter issue. And these dealers are all across the country.
They ALL agree: The only filter that needs to be replaced at 15k is the one under the hood which is the element type. They tell me this came in a service bulletin from RAM/FCA And it is NOT $100 at O Rielly.The WIX is $66.99 (which dont get me wrong is expensive but it;s a far cry from $100) The other filter is about $86 and some change. these prices are in Tucson.
The other filter located above your drive shaft can be changed at 30K+ miles.
The dash readout pertains to the Fuel Filter under the hood on the engine.
