SoCalDesertRid1
Jun 19, 2016Explorer
Flatbed it! :D
You don't have to put the bed way up high, if you have a 4wd and heavy duty springs, with stock or near stock diameter tires. The tire won't reach the height of the wheel wells in the pickup box anyways, so you can set your flatbed deck about half way between the normal pickup bed floor height and the wheel well height.
Leave out the outrigger cross member right above the tires and either notch the outboard side rails above the wheels, or make the bed wide enough that the tires' upward travel is within the bed width. The tire won't touch the bottom of the deck and will miss the channel sides.
