Tailwind44's avatar
Tailwind44
Replacing oven question
I have to replace the range in my TT. Wondering if it is possible to install a cook top and microwave/convection oven below it rather than whole slide in unit? Or if I should just replace whole range? Anyone have ideas about this?
  • Most convection ovens do not have to be vented to the outside in an RV, but they do require some air space. BTW - my cooktop/ oven in in a slide - and it doesn't vent to the outside either.
    Your regular over in likely 21 1/2 inches wide. The Dometic 1100W Convection Microwave we added to our TT is 22 1/2 inches wide. We had to alter the trim (cut it away) to have room for the Convection/Microwave.
    One thing to consider - without an outside vent - the convection oven will add quite a bit of heat to the inside of the trailer. We've baked whole chickens, steaks, cookies, biscuits, etc in ours - but mainly in the winter.
    While the convection adds quite a bit of heat in the summer - it will cook almost anything an oven will - and a lot faster than the over - especially if you use a combination of microwave and convection. So the net heat increase is smaller in my experience with a convection than a propane oven.
  • I have a friend with a Toy Hauler that came with the cooktop/convection microwave combo. Keep in mind that you will need shore power or a generator to use your oven - his Toy Hauler came equipped with a (very noisy) generator. The propane stove/oven combo needs no electricity to operate.
    We often boondock without hookups, and if in a campground, breakfast is usually before generator hours. The convection/microwave wouldn't bake my biscuits!
  • robsouth wrote:
    As a contractor friend of mine told me once "Whatever you have the money to do is possible". If that is what you want and can afford, then do it. If not, then don't do it. It's just cabinetry work.
    Best answer so far. :)
    The OP needs to give a whole lot more information (make / model / year of trailer, what is the desired outcome, etc.) if he wants informative answers, and a picture would speak volumes.
  • We dry camp about 4 times a year, so the gas stove is a must for us.
    but you know what's best for your camping needs. go for it.
  • As a contractor friend of mine told me once "Whatever you have the money to do is possible". If that is what you want and can afford, then do it. If not, then don't do it. It's just cabinetry work.
