silverbullet555
Aug 07, 2021Explorer
Reseal questions on or near roof
Local shop resealed most of my roof, but I have a couple more things I want to do. It's fine, because I didn't pay for a full reseal.
I'm curious about best ways to handle a couple things. Pics attached and hopefully I can embed them in order.
First up are the gutter screws. Quite a few have loosened over time. I'll go and snug them up. In boats, we would bed those in 3m 4200 to seal it. Should they be bedded here, and if so, with what? Or keep them dry? The gutter down spot has a hole in it so I need to repair or replace it at some point, but I don't have the part here.
Along the same lines are the tops of the gutters. It looks like they could use a bead of dicor non sagging. Would that be correct?
Next up is the where the roof meets the gutter on the other side of the corner. I don't like that gap there. I'm thinking dicor non sagging to fill and seal that area?
Next up is where the membrane is just starting to show some cracking. Eternabond or dicor non sagging? Would eternabond make that corner and stay adhered?
Last up are the tracks for the thule racks. I'm afraid if I top off the dicor that is there, it'll make it impossible to move the sliding nuts inside which things mount to. Maybe that is a non issue as there are other ways to get them out.
Experience or thoughts on the best way to seal the racks?
