Sybrina
May 30, 2022Explorer
Reverse polarity
I hooked up my battery backwards on my 1994 skyline Layton and now my slider won't extend. What is the problem and where can I find it?
LScamper wrote:
So the slide works with the battery alone with nothing coming from the converter? That would be the same as the reverse polarity fuses being removed. The fuses are not needed to use the slide! So bad fuses will not stop slide from working.
