ssthrd
Jul 23, 2023Explorer
Rieco Titan 2500# jack is binding.......
Right out of the blue, the jack stopped, and would not work either up or down. I checked the receiver and found that the lights came on for all 4 jacks both up and down, even for the stuck jack. When I try the jack while charging the batteries with my generator (the batteries are fully charged) I put a hand on the jack motor, and can feel it trying to move both up and down, but it is definitely stuck. This tells me that power is not a problem, so the issue must be mechanical. All fuses are fine, and the other 3 jacks operate as they should.
Anyone had a problem like this, and if so, what was your fix? Gears binding? I'm going to block up the RR corner and have a look, but a bit of knowledge going in would not be a bad thing.
Thanks!
Forgot to add that I tried to turn the spindle/motor with a ratchet, and it turned maybe 5 degrees before binding. Adding a bit more pressure (maybe 50 lbs ft) it let go for maybe another 5 degrees before binding again. Is there an overload ratchet system in these jacks?
Thanks!
