โJan-11-2023 08:47 AM
โJan-20-2023 05:08 AM
blt2ski wrote:
No plates out.
โJan-20-2023 03:48 AM
map40 wrote:
Most EVs have an electric clutch (or connect/ disconect) between the wheels and the transmission. They don't have many components but they have a single or in some cases a 2 speed transmission (very simple, nothing like what am ICE has)
Due to the high torque of the electric motors, the traction control systems are much more complex than ICE's and monitor wheel speeds with a much higher frequency and precision.
The same problem happens with the regenerative breaking in snowy/icy condition. It is very easy to loose traction on ice and as it is involuntary (meaning the driver does not press the brake or anything else, it is activated automatically) so the system is monitoring not only the wheel speed independently several thousand times per second, it also triangulates with GPS and accelerometers to ensure the wheels are always "in traction".
All of this said, the problem is that flat towing something that complex may create unforseen problems, so lawyers said "How many more sales are you going to get by allowing flat towing? Is it really worth the risk?" And the answer was always "No".
There is no inherent technical reason (like the transmission in an ICE), it is simply "Why risk it, we are selling every unit before its built..."
I have towed one of my leafs and one of my BMW but just to see how fast did they charge, and o boy did they complained!
โJan-19-2023 09:05 PM
JRscooby wrote:time2roll wrote:
After a bit more reading... Rivian seems to no longer endorse four-down towing of the vehicles. ๐
Bollinger had made the same comments and then shifted out of the personal market to focus on commercial.
There are no EVs that can be towed on all four wheels that I am aware of.
Can anybody tell what the issue is that would prevent flat towing? For years, ICE cars was the transmission did not lube itself unless the input shaft was spinning. Which implied spin the engine. EVs don't have transmission, so that's no problem. No disconnect between wheel and motor? Well spinning the motor, with no power to it, does no harm, as long does not exceed speed it would normally run. (Going to tow faster than you would drive?) Steering and brakes would be no more complicated than ICE.
โJan-19-2023 08:28 PM
โJan-18-2023 04:27 AM
Reisender wrote:
Thatโs kind of what Toyota is working on. I saw an article a week or two ago. I think it was titled hitchless towing or something like that. A google search might bring up something.
Essentially a vehicle with self driving autonomy would do that. There are a few manufacturers working on that although I think itโs still 2 or 3 years away. Who knows. The challenge would be the vehicle still needs to be fueled or charged manually. But of course there will be solutions for that too.
Fun to watch the technology change.
โJan-18-2023 03:30 AM
โJan-17-2023 12:25 PM
Grit dog wrote:JRscooby wrote:
Another idea; If driver of MH could power up the toad on the fly, make toad pull itself, or even push, on steep hills, or when need to accelerate.
This would make room in battery for the regen.
ROFL. Or what if it could fly, like a Jestons car, or teleport itself to the next destinationโฆ.
Oh wait. Self driving is basically fully functional. You could have it virtually hitched to the Mohoโฆ..
โJan-17-2023 11:59 AM
โJan-17-2023 09:07 AM
Grit dog wrote:Some day my old truck and 5th wheel will get retired. I expect my next RV is a Class A or Super C. At that point I want an EV to pull behind.
What would you be trading up fromโฆ..you know, if it could be a 4 on the floor toad?
โJan-17-2023 08:48 AM
โJan-17-2023 08:10 AM
JRscooby wrote:Huntindog wrote:time2roll wrote:agesilaus wrote:I am still waiting to get a report on using a Rivian as a toad. If it works I might just trade....
Not of great interest to Class A, B and C Rvers.
Could it be setup to add braking on a downhill? Regenerative?
โJan-17-2023 07:52 AM
โJan-17-2023 07:39 AM
time2roll wrote:Huntindog wrote:After a bit more reading... Rivian seems to no longer endorse four-down towing of the vehicles. ๐time2roll wrote:agesilaus wrote:I am still waiting to get a report on using a Rivian as a toad. If it works I might just trade....
โJan-17-2023 05:56 AM
