4x4ord's avatar
4x4ord
May 13, 2021
Rubber bumper suspension stops
How much clearance is considered enough?
  • Looks like you didn’t land any fish on this trip....
    Weight cops mustn’t be biting today...
  • 4x4ord wrote:
    dodge guy wrote:
    Those aren't stops. they are suspension bumpstops. and will compress when under load. is the 5`er hooked up?
    The pic is with a gooseneck trailer hooked up ..... about 5k lbs of pin weight.
    Then that’s exactly where they should be.
  • 4x4ord's avatar
    4x4ord
  • They basically act as overload springs, but without the spring slap or excess rebound. They can be fully engaged.
  • Those aren't stops. they are suspension bumpstops. and will compress when under load. is the 5`er hooked up?
  • Yeah, eyeballing, it looks like about 1" of articulation before it hits the stop.
    When I installed sumo springs on my F250, there was around 5" when empty (to the OEM bump stop) and putting the 5th wheel on at up a little less than 2" due to sag.
    I assume you are heavily loaded and every bump you hit, the axle is going to bottom out.
  • That appears to be too close, IMO. What is the truck model? I assume the camper is attached? What about cargo in the bed and passengers?
