ret_usn
Oct 25, 2017Explorer
sewage valves.
On our last trip I noticed the gray valve was leaking and dripping at cap. Dumped before leaving. Just got under to attempt to replace both dump valves since this is a 2004. Found a box with pipe in the middle and a handle on each side. removed 4 screws and with the box loose I discovered the valves are 3' in at tanks and are cable operated. Had to remove 2 sheets of metal under camper to even see them. Now I am considering removing all the pipe which is connected at the tanks with a rubber sleeve and clamps. I think it is best to remove the complete unit , replace cable operated valves and cable to box and then reinstall. Any better ideas>??
